at and atx psu's
Discussion in 'Power Supplies and UPS's' started by Emo Elmo, Dec 20, 2007.
  1. Emo Elmo
    Emo Elmo Geek Trainee
    I was just wondering if an at power supply is smaller than a atx power supply??
    any help is would be great
  2. zeus
    zeus out of date
    AT PSUs are much bigger. Different shape too.
  3. Emo Elmo
    alright thanks
  4. Big B
    While there may be a physical difference, the key differences are this:
    AT have a wired switch that goes to the front of the case; ATX work in conjunction with the motherboard for a soft switch. Here, there is still a switch up front, but it's wired to a header on the motherboard.
    The other major difference is the main power connetor.
    AT power supplies use 2x 6-pin leads, where ATX uses one 20 or 24-pin (24-pin is newer).
