Hi
I have a strange problem that I have traced to my graphics card or drivers. I run an older PC with fully up-to-date Win XP Home SP3. My graphics card is an ATI Radeon 9550 which has been in the machine for 3 years; it connects to a flat screen via DVI.
A couple of mornings ago, after switching on, the screen was blank but the HHD light would flicker now and then.
I re-booted in safe mode and when the driver loading got to Mup.sys, Windows hung for some time before eventually starting successfully in safe mode.
I could not find anything definite about Mup.sys and after much fiddling decided to re-install Windows. I did a careful re-install, checking I could successfully re-boot after each addition. When I loaded the graphics, the system hung with all the previous symptoms. A system restore saw the PC working. I downloaded the up-to-date graphic drivers from ATI, same problem.
My last resort was to open the machine and clean everything, but the graphic drivers are still causing the same problem.
I am running on the basic Windows graphics with a stuttering screen display.
Can anyone solve this problem for me?
Thanks
Thanks
