Belkin Bluetooth USB Adapter trouble
Discussion in 'Networking and Computer Security' started by Mofrait, Jan 16, 2008.
  1. Mofrait
    Mofrait Geek Trainee
    Hello,
    I bought this adapter for my bluetooth Wacom tablet (both 2.0). I've gone through the software/driver installation process many times, using different versions and double checking that each had no problems installing. So the problem is: it will not detect my USB adapter. When I plug it in it tells me the hardware did not install properly. I have no leads and haven't found anything off google.
    Anyone have and idea?
    Thanks.
  2. donkey42
    donkey42 plank
    it probaly has the USB controller disabled in the BIOS or either the USB device doesn't work or one of your USB ports is dead, have you tried a different USB port, obviously if you have more
  3. Mofrait
    Yes I have, in all 6 different ports. If the USB controller was disabled in the BIOS, would that mean the USB port itself is disabled, or the Belkin devise is disabled?
    I'll take a look and let you know what I see, thanks donkey.
  4. Mofrait
    I checked the controller and it was eneabled. I enabled the USB legacy to see if that might help, but no luck. (it was auto before):x:
  5. donkey42
    donkey42 plank
    yeah, USB Legacy devices enables stuff like USB keyboards & possibly mice :unsure: but definitely keyboards
