broadband speed up ?
Discussion in 'Linux, BSD and Other OS's' started by donkey42, Sep 21, 2007.
  1. donkey42
    donkey42 plank
    just thought i'd try deleting stuff from Swiftweasel's download manager while it was downloading & my download of debian when into overdrive, i've added a couple of screenshot so you believe me, i haven't tried it with FF yet,
    my download rate is usually about 60K/s and i have a 512 service
    but look at these download rates
    could someone else try this to make sure it isn't a fluke
    Edit: and my router's download light was nearly on permanently, or is it just me ?
    BTW: trying FF later
    Edit: using Kubuntu Feisty
  2. RHochstenbach
    RHochstenbach Administrator
    If your connection speed is 60 Kbits/s, then it is 480 KBytes/s. So it is the actual connection speed. I've calculated it on this way: 60 Kbits is 60.000 bits. 1 byte = 8 bits. So 60.000 x 8= 480.000 bytes = 480 KB. Kb means Kilobits (1000 bits). And KB means Kilobytes (1000 bytes). Most download managers show KB/s instead of Kb/s.
  3. donkey42
    donkey42 plank
    no my connection is usually 60KB not 60Kb (look at the screenshots)
    so, 1KB = 1024 Bytes, not 1000
    your right about 8 bits = 1 byte, but, 1 Byte = 1024 bits
    Source
  4. RHochstenbach
    Both the screenshots show a transfer rate of 400-460 KB/s. But it could be possible that the file is hosted on a fast server or your ISP has increased the connection speed.
    No, 1 byte = 8 bits. 1024 bits = 1Kbit. (=128 bytes, because 1024 divided by 8 = 128).
  5. donkey42
    donkey42 plank
    i've got a headache, i'll agree to anything, just change the subject
    BTW: installing debian 4 into VMware
  6. donkey42
    donkey42 plank
    RH you misunderstood this thread, i'll explain, stuff usually downloads @ about 60KB/s, however, i noticed the download speed go up to over 400KB/s if i deleted previously completed downloads while currently downloading debi
  7. RHochstenbach
    Does this happen all the time, or just this time? If it suddenly happens all the time, then I think the ISP has increased the connection speed of your subscription. Otherwise, I don't know.
    btw thanks for correcting me :beer:
  8. donkey42
    donkey42 plank
    it happens every time i delete previously completed downloaded files and watch the current download speed of a download
  9. RHochstenbach
    It could be a bug in the browser, I guess :confused:
  10. donkey42
    donkey42 plank
    well if it is a bug then i want more bugs like that, my connection was actually over 6 times faster, do you know anywhere i can report it, because, if you could have the browser permanently deleting virtual downloads, to increase the download rate on linux
    BTW it also works with Firefox2, very :confused:
  11. Fred
    Fred Moderator
    Does this increase occur for the entire remainder of the download? I often see a very high download rate at various times during downloads (more so immediately following a resume or the start of one). But this increase always slowly dies down, whether on FF, SF, or Opera. As an example, my normal download speed is about 300 KB/s, and it will sometimes show as as much as 1000 KB/s and then slowly die down to the normal download speed. I never have thought anything of it.
    *edit*
    *cough* Or even epiphany and Iceweasel (to be specific) :-P
  12. donkey42
    donkey42 plank
    no, it slowly drops in speed back to about 60KB/s
    i'm using Swiftweasel & it also does it in FF & SF , will try other browsers
    BTW: it doesn't seem to have any impact on Swiftdove
    i'll throw them in and see what happens, although, the download history will need filling, to be able to delete stuff
    Edit: it seems to only work on Gecko based browsers
    i think it would be better if someone else does more research on this, as i don't feel that i am able to up to doing it because i'm brain damaged & sometimes i don't understand stuff like Linux, yes i've being using it for about 2 years, but i have a lot of bookmarks to help me
