Capture Card Troubleshooting--Does anyone know a solution?
Discussion in 'Video Cards, Displays and TV Tuners' started by Austin Covello, Feb 4, 2011.
  1. Austin Covello
    Austin Covello Geek Trainee
    I have four Sabrent USB-AVCPT capture cards running under Windows 7, each attached to a camera. I have attempted to attach 4 of them at a time so that I can open four instances of a video-chat program--one for each camera. The problem is that the program will only recognize one of the cameras. When using a Gigaware USB hub, it will recognize two, because for some reason port 2 gives one of the cameras a different designation from the other three. I was wondering if there was a way to get different designations from the hardware so that the program I'm using recognizes them separately? I've tried renaming aspects of the registry, which either doesn't work or (more likely) I didn't do it correctly. Does anyone know how to do this, or can point me toward a tutorial that will allow me to do this?
    UPDATE: The program I'm using uses a Microsoft Directshow API to view the camera video. Is there any way I can modify it to view multiple cards on the same driver? Thanks again.
