Hi all, I am putting together a spec for a Mini ITX PC and was hoping someone would be able to confirm if all items are indeed compatible. Case: Cooler Master Elite 100 Motherboard: ZOTAC NF610i-K-E CPU: Intel Core 2 Duo E7400 2.8GHz Memory: Kingston 1GB DDR2-800 The above are linked for more info. The case is passively cooled to CPU 75w and the CPU is 65w (I think that's right!) so no Heat Sink. I'll also be adding a SATA HD and DVD RW, the case is shipped with 1 SATA cable so I'll get another. For a bare bones system, have I missed anything? Thanks!
Hi, It looks like all the parts should work together, Socket t is the same as lga775 which I didnt know till I just looked it up . The only thing I can think of is you might want to check a wattage calculator to be sure the 150w power supply can handle all of the parts you will have. When I tried this calculator for what you seem to planning to buy, its coming up closer to 200w which is more than the 150w that is part of the case, so you may have to find another powersupply. http://www.antec.outervision.com/PSUEngine
Hi and thanks for the reply...glad it looks right, was for an assignment that's been handed in and waiting marks The PSU calculator is a great tool, wish I knew about it before but good to know their out there!
