Raistlen007
Geek Trainee
Computer Specs:
Motherboard: Intel D915GAV
RAM: 1GB
Video card: Geforce 7300
Sound Card: Creative Audigy SE
OS: Windows XP PRO
Hello,
I have a problem that whenever my samsung DVD burner either reads or writes info to or from a CD or DVD my computer becomes unbearebly slow, mouse curser becomes jumpy and sound begins to stutter. The slowdown also causes the DVD to read at a rate of about X1.3 which is obviously not OK, and it burns at about a quarter of the speed it should. (A full DVD takes 45 minutes instead of the 13 minutes it should take. Whenever the DVD reads or burns a CD, the computer slows down and the sound gets all jittery.
This started when I replaced the 2nd DVD reader on the IDE strip with a 40GB ATA HardDrive, which I need. The motherboard doesnt have a second IDE strip. Buying another SATA HardDrive isn't an option, either.
I thought it might be the sound card, but when disabled, and using the on board sound chip, there is no difference.
Also, there is a PCI network card which is currently disabled, but when enabled, causes the sound to be jittery and intermittent, but only when there is network traffic going through it. I don't know if this is related to the main problem.
What would cause this and how can I fix it, if possible, without replacing anything?
RAM: 1GB
OS: Windows XP PRO
Hello,
