I'll update this thread as an when everything is here e.t.c But sometime this week i have arriving: Akasa AK-PAX-2 PaxMate Plus Acoustic Absorption Mat (Deadens Vibration & Noise of case / fans / hdds) Arctic Cooling Freezer 64 CPU Cooler 2 x 80mm Silent Vantec Case Fans - 20DB @ 2100-2200RPM Then sometime in the next 2 weeks i have arriving 512MB-1GB of PC4400 OCZ GE, depending on when i order it Hopefully i'll be reaching my ultimate dream - a good nights sleep with my pc being left on!
I must be a very heavy sleeper coz i can sleep with my pc on and it has 4 fans and one of the gfx card and its very loud.
sounds like it My PC isn't loud, it's just the frequency it makes is irritating and not a soothing noise Boland on a different note, how are you running an Athlon 3200+ with PC2100 memory? the 3200+ requires an FSB of 200Mhz, and PC2100 only provides 133Mhz.
My rigs aren't all that loud...now that rackmout switch is a bit noisy. It doesn't bother me all that much really. If I'm tired, I will go to sleep (even when my little bro has band practince outside my room).
My pc is very loud, with 7 fans in total, one of which is 12cm's wide. Mind, the case is of fairly poor quality, which no doubt allows the fans noise to reverberate around the inside. Don't notice it too much when using it as either loud sounds of screams and death or music. Which in my case tend to sound the same.
lol I just looked at the HSF. holy mother of god. That's a fat assed piece of kit. Is there actually room in the case for that, or is it not as big as it looks?
Well literally the only thing making noise in my computer now is my graphics card, everything else is literally inaudiable :good: I can highly recommend the Artic Cooler Freezer 64, stock my temps are: CPU:29-31C (idle) 36C Load SYS:22-25C PWM:26-29C Going to stress it out with some F@H and see what the temps look like OK, with my computer OC'd to 2.3Ghz from 2.0Ghz: FSB 230 x 10 / LDTx4 / DDR VDimm: 2.7V temps are: CPU:33C (idle) 41C Load SYS:25C PWM:34C And thats after running F@H for an hour
Sounds like you got a happy little system thar. Right now I have 10 fans in my case. 4 of which are vantec stealths producing almost no noice, but my case does VERY good dampening fan noise and vibrations
