cpu fan error
Discussion in 'CPU, Motherboards and Memory' started by sudharsanan, Mar 14, 2011.
  1. sudharsanan
    sudharsanan Geek Trainee
    I have the asus 845 motherboard , display the error "CPU fan not correctly fitting" and system goes to down but my CPU cooling fan has fitting correctly, how to clear the error
  2. Ghostman 1
    Ghostman 1 Mega Geek
    Check the fan to make sure it is running, Next go into the bios and see if there is a spot in there to clear... If not ! Try removing the bios battery for a couple minutes..
