Hi All, I have an old 8 yr old Samsung Samtron 55V CRT monitor, which I got it repaired yesterday because of heavy flickering problem since the last couple of months! I did notice that technician replaced a faulty on board filter capacitor: defective on board - 150 uF Replaced with - 220 uF Will there be any problem with this monitor performance or will it draw lot of power? My domestic power line is 220-240V AC. Please reply. Thanks, bulava
No I agree overrating by so little should be fine, it is underrating that you need to be careful with. Be careful if you are poking about in the back of a CRT, very dangerous! Unless you are on a 3inch thick rubber matt in a proper electronics lab! Even then - I stay clear!
Thanks for your suggestion but am not fiddling with that CRT monitor as I aware of such dangers. Now there is no problem with that monitor
