DDR motherboard with GDDR3 vid card? can it work?
Discussion in 'CPU, Motherboards and Memory' started by s2k, Jul 18, 2008.
  1. s2k
    s2k Geek Trainee
    I'm updating my graphics card, and i'm trying to avoid buying a new motherboard, if at all possible. The card i'm looking at is a sapphire 100229L Radeon HD 2600XT 512MB 128-bit GDDR3 AGP card. I do have a agp slot so i know it will fit, but i am unsure if the GDDR3 is compatible with a DDR motherboard.
  2. donkey42
    donkey42 plank
    it's not a problem, the gfx card memory controller is nothing to do with the memory controller on the mobo
    the only thing you need to worry about is:
    1, what type of AGP port your mobe has, what make & model is it ?
    2, what type of AGP gfx card do you want to add ?
