DVD-rw Problem
Discussion in 'Storage Devices' started by Typical, May 15, 2005.
  1. Typical
    Typical Geek Trainee
    I just installed a DVD-RW drive and my computer fails to recognise it. When the computer boots, if I open the drive the system freezes and have to go through the problematic adventure of getting the computer to load up again whether it's in safe mode/normal/previous configs etc.
    The drive came with no instructions or cables. I am using a...
    Dell Dimension 4400
    2.0 GHz P4
    768mb Ram
    80GB
    etc
    I would tell you what make the drive is but that would require opening the tower up for the tenth time today.
    Any ideas?
  2. Sniper
    Is the drive set as a master drive (on the secondary IDE channel)?
    Also try a different IDE cable to see if it helps.
  3. Typical
    I believe it is, yea.
  4. Typical
    Problem solved. :)
    I switched the DVDRW drive to a slave drive so the CD/DVD ROM drive is the master.
    Thanks
