Excel problem
Discussion in 'General Software' started by louie007, Oct 19, 2006.
  1. louie007
    louie007 Geek Trainee
    I was wondering if there are is any ways to add a comma to the end of a number for each cell that I have which is over 10,000
    Why am I doing this, it has to do with a database search query. Any help would be appreicated. Thanks to you for reading this.
    For example
    Want all numbers to look like 4, 10, 125, in there own cells.
    Cells:A1 4
    A2 10
    A3 125
  2. zeus
    zeus out of date
    I needed to do exactly the same thing.
    It was a bitch to get it to work in the search engines though. I had my list in a column and needed it in one row and 2,000 odd columns. Quatrro Pro goes up to 18,000 odd. Excel only does 256.
    How are you doing your search? I couldnt find a program that search for exact text!
    http://www.hardwareforums.com/excel-add-character-end-each-cell-14675/
    Its the bottom of my second post you want.
