FSB Speed Question
Discussion in 'CPU, Motherboards and Memory' started by Dean me, Oct 16, 2007.
  1. Dean me
    Dean me Geek Trainee
    I am going to upgrade my PC soon, getting a new processor and RAM first. My question is, what FSB speeds of the RAM and CPU do I have to try match for efficiency?
    I have heard things about core 2 duo's quad pumped FSB and Double Data Rate changing the effective speeds, so could someone please make it clear to me?
    My motherboard is the ASUS P5N32-E-SLI-PLUS
    I don't know whether i should get a CPU with a 1000mhz or 1333mhz FSB. I plan on getting 800mhz RAM since i don't think my motherboard supports any higher RAM speed.
  2. Runner7775
    Runner7775 Geek
    i would get the one with the 1333 mhz bus if you can afford it but i dont think i can explain the fsb codewords effectively
