Hard drive replacement
Discussion in 'Storage Devices' started by rexyiscool, Nov 29, 2011.
  1. rexyiscool
    rexyiscool Geek Trainee
    Well recently my 1tb sata hard drive broke, so i bought a new 500gb green caviar WD internal hardrive. I installed it as i did my first one. After installation i tried booting up and it said " Reboot and Select proper boot device or Insert Boot Media in selected Boot device and press a key."
    I went to bios to look for a solution, and my new hardrive wasn't even listed as a boot/storage device. I tried again with my old hard drive(still worked but crashed after boot) and the same thing happened.
    I even tried switching what ports the Hard drive was connected to on the motherboard, to no success.
    Any help, I've been trying to get this computer up and running for weeks.
    Thanks
  2. tking0036
    tking0036 Geek
    The problem is that this new hard drive is empty, is not formatted , and has no operating system. You are going to have to reinstall your operating system to get your computer up and running.
