Hard drive temp
Discussion in 'Overclocking & Cooling' started by Girtho961, Sep 13, 2005.
  1. Girtho961
    Girtho961 Big Geek
    Is 31*C a good temp for a hard drive. THis is according to PC wizard 2005
  2. Big B
    That's not incredibly hot number by any means. I'm not entirely sure what are the okay zones for hard drives, but with that number, I don't think I'd really worry.
  3. pelvis_3
    pelvis_3 HWF Member For Life
    That is a safe temperature!
    My HDD idles at 30 and on load it's 35!
    If it were to go over 40 than you can start thinking of a solution!
  4. sabashuali
    sabashuali Ani Ma'amin
    Mine normaly sits at 29-30.
    under presure (Video or games) it will probably rise to 32-33.
    However, this could be due to the intake fan situated in the front between the two HDDs...
    If it was not there it might have been higher.....
    Maybe try and do that if you are worried. Also, hd coolers are not very expensive and are really easy to fit...
    By the way Big B - which will be hotter - SATA drive or IDE? Or should it make any difference?
    Just had a quick look at Seagate and Fujitsu sites and in both places the recomended operational temps are 5-50C. They did however mention adequet cooling.....
    Keep it (AC) cool!
  5. Addis
    Addis The King
    Neither, the difference between SATA and PATA is the controller and interface, the actual disks are the same.
    sabashuali likes this.
  6. Matt555
    Matt555 iMod
    yeah i currently have no fan blowing over my HDD :( its idle temp is about 38*C, and under load it can reach 42*C, if i put my HDD cooler on it it lowers to 25*C but the cooler is noisy...i dont like noise from my silent computer anymore
  7. sabashuali
    Can I ask what PSU are you using?
  8. Matt555
    Matt555 iMod
    its a Tagan TG480-U01 Black Silent Edition PSU (480Watt)
