HDTV Support :: Need Help
Apollo1020
Geek Trainee
Hi all. I need your help. This is URGENT.
I need to know what Displays/Monitors support Full HDTV. I'm planning to buy Dell's XPS 420 Desktop with Dell's Display/Monitor. They're offering Displays/Monitors up to 24 inch. I've choosed 20 inch UltraSharp 2007WFP Widescreen Display/Monitor. Will this be enouph to view movies in Full HDTV? If no, anyway... please, tell me what Dell's Displays/Monitors support Full HDTV. The inches, everything.
Please, who know what it's all about - reply as soon as possible. I need a list of Dell's Displays/Monitors, which support Full HDTV.
I thank you.
When you say "Full HD" do you mean 1080p resolution? which is the highest standard of resolution, totalling: 1920×1080 pixels. So look for a monitor which supports that resolution and you'll be laughing.
Yes, it supports 1080p, but not over the component connection, but nobody uses that for a monitor anyway, but yes, coupled with a relatively decent graphics card, should be perfect.
