Help! firewall not working right
Discussion in 'Networking and Computer Security' started by jester45, Aug 23, 2006.
  1. jester45
    jester45 Big Geek wanna be
    my firewall isnt working right and is letting connections start a startup i checked the log and it blocks many etemps then lets 2 connect and my router starts blinking like im downloading when i restarted the first time it asked to let a program connect and i said no then looking a the log there was a program named n/a attempeding to connect ot ports like 33000 and other ports i never use
    im useing lavasoft personal firewall professional and its not trial
    also i uploaded 2 txt files becuase the blocked port/ip list is way to long
    please help
  2. Impotence
    Try running " Ethereal: A Network Protocol Analyzer " to see whats actually in the packets being sent.
    If your wanting to capture packets coming from the machine @ startup run ethereal on another machine, you will ether have to have both machines on a hub (not a switch, as packet switching means you only get traffic with your address on it sent down your wire) or use ettercap to posinin the ARP cache of your "suspect" machine (means the traffic from your suspect machine will be routed through the investigating machine, ettercap allows you sniff on packet switched networks)
  3. jester45
    is there no way of just stoping it or how about a diffrent firewall i would like to have it block anything then every time a program asks to uyse hte internet i give it for each program that way i know whats getting on or not o and my router has a hardware firewall why is this not stoping it
  4. Chris_
    Chris_ Excalibur
    Download Sygate Personal Firewall, disable your Internet Connection (Start > My Network Places > View Network Connections), then Uninstall Lavasoft Personal Firewall Professional from your computer.
    Install Sygate make any necessary reboot's and when you logon, if any malicious files are trying to access a remote machine (vice versa), you can look at them In more detail, and report them here.
    I think that you might be infected with virii.
  5. jester45
    i have ran avast! Lavasoft and defender the avast was the home addidton lavasoft and defender was pro
    i will try sygate
    somethings i think should be easier like block all port unless i say so so much easier
  6. Impotence
    Or, If you switch to linux you wont have to worry about malware! (and the firewall is part of the kernal!!! :D)
    You can install ubuntu in under and hour & run automatix after to install any extra's you mich need in about the same (mp3 & dvd codecs, P2P apps etc) but most general use things such as word processors are allready installed!
  7. jester45
    yea i want linux i have a ubuntu cd but no computer to put it on i tried a 2nd hardrive with xubuntu but a error came up when trying to boot from drive im thinking about getting a cheap barebone system to test lunix out and get used to it before i put it on my good computer or i might make a server with it i do hate windows micr$oft and bill gates for makeing windows o and dell becuase they suck
  8. Karanislove
    Why not just install as a secondory operating system??
    Completely agree.........
  9. jester45
    what about micro$oft
    becuase i just started a new topic on it im doing "testing" or more like controled destruction it will get desroyed just a matter of time might need a hammer for it
  10. Karanislove
    Dont go on their name........... Its not micro + soft in reality.
    I believe its macro + hard coz upto now, no one is able to beat them up.
  11. Ghostman 1
    Ghostman 1 Mega Geek
    I am testing that same firewall right now and it seems to be very good.
    Have you tried to just reinstall it? After i install ANY firewall I would test
    each and everyone at Gibson's Research with Shields Up.
    Lavasoft firewall passed all the test,So i would reinstall it and try it again.
  12. jester45
    ok will try that
    o and Karanislove i dont like your new sig put the old one back on
  13. Karanislove
    [ot]
    Cheers mate! actually I changed it coz admins doesnt like the big signature and it doesnt looks good in small size but if you insists then I think that I've to go with it....
    [/ot]
  14. jester45
    cool now back on topic but im gonna buy a new computer soon so i will just wipe the whole drive and do a freash install so no more virus
