Help me with error 633
Discussion in 'Windows OS's' started by Smoka, Dec 16, 2009.
  1. Smoka
    Smoka Geek Trainee
    I have a windows Xp and i have 3G modem internet.....HUAWEI
    I have tryed everything on internet nothings works....
    What to i do? I get error 633 all the time nothing works...
    I cant find telephone.ini file no where....How to find this file in windows XP???
    Instaelled and uninsyalled the program etc. nothing
    Any help
  2. donkey42
    donkey42 plank
    idealy this should have being posted here anyway more info would help, like which HUAWEI device are you using e.g. E220, E176, E169G etc. etc.
    but i'll try diagnosing your prob anyway
    and were you using a proxy, this may be of help to you because it contains the location of telephon.ini and details rebuilding it
  3. Smoka
    Smoka Geek Trainee
    Ok thank you the device is HUAWEI E 169.....
    It would be nice if i can figure this issue.Beacuse i tryed everything, strange thing is that it(modem) works on my laptop.I used this connection on my pc for 7 month and after the problem accured on my pc i tryed it on my laptotp...works fine.Don't have no idea waht could caused that kinda behavior of a PC.
    Still i don't find the file.
