help with ram upgrade
Discussion in 'CPU, Motherboards and Memory' started by gradd001, Jul 3, 2008.
  1. gradd001
    gradd001 Geek Trainee
    i am planning to buy a 1gb ddr1 ram pc400 but i don't if my motherboard can support this ram. Can a p4m266a-8235 support this memory?
    Code:
    --------[ EVEREST Home Edition (c) 2003-2005 Lavalys, Inc. ]------------------------------------------------------------
        Version                                           EVEREST v2.20.405
        Homepage                                          [URL="http://www.lavalys.com/"]Lavalys - Comprehensive IT Security and Management[/URL]
        Report Type                                       Report Wizard
        Computer                                          OM (my computer)
        Generator                                         Administrator
        Operating System                                  Microsoft Windows XP Professional 5.1.2600 (WinXP Retail)
        Date                                              2008-07-03
        Time                                              10:58
    --------[ Motherboard ]-------------------------------------------------------------------------------------------------
        Motherboard Properties:
          Motherboard ID                                    04/15/2003-P4M266A-8235-6A6LW00HC-00
          Motherboard Name                                  VIARAMA U8668 (Pro)
        Front Side Bus Properties:
          Bus Type                                          Intel NetBurst
          Bus Width                                         64-bit
          Real Clock                                        100 MHz (QDR)
          Effective Clock                                   400 MHz
          Bandwidth                                         3200 MB/s
        Chipset Bus Properties:
          Bus Type                                          VIA V-Link
          Bus Width                                         8-bit
        Motherboard Physical Info:
          CPU Sockets/Slots                                 1
          Expansion Slots                                   3 PCI, 1 AGP, 1 CNR
          RAM Slots                                         2 SDR DIMM, 2 DDR DIMM
          Integrated Devices                                Audio, Video, LAN
          Form Factor                                       Micro ATX
          Motherboard Chipset                               P4M266
        Motherboard Manufacturer:
          Company Name                                      Biostar Group
          Product Information                               [URL]http://www.biostar.com.tw/products/mainboard/index.php3[/URL]
          BIOS Download                                     [URL]http://www.biostar.com.tw/support/bios/socket.php3?socket=775[/URL]
    --------[ Memory ]------------------------------------------------------------------------------------------------------
        Physical Memory:
          Total                                             255 MB
          Used                                              188 MB
          Free                                              66 MB
          Utilization                                       74 %
        Swap Space:
          Total                                             1259 MB
          Used                                              374 MB
          Free                                              884 MB
          Utilization                                       30 %
        Virtual Memory:
          Total                                             1514 MB
          Used                                              563 MB
          Free                                              951 MB
          Utilization                                       37 %
        Physical Address Extension (PAE):
          Supported by Operating System                     Yes
          Supported by CPU                                  Yes
          Active                                            No
        Problems & Suggestions:
          Suggestion                                        Install more system memory to improve applications performance.
    --------[ SPD ]---------------------------------------------------------------------------------------------------------
      [ DIMM1: Samsung M3 68L1713DTL-CB0 ]
        Memory Module Properties:
          Module Name                                       Samsung M3 68L1713DTL-CB0
          Serial Number                                     F207FAD2h
          Manufacture Date                                  Week 7 / 2003
          Module Size                                       128 MB (1 rank, 4 banks)
          Module Type                                       Unbuffered
          Memory Type                                       DDR SDRAM
          Memory Speed                                      PC2100 (133 MHz)
          Module Width                                      64 bit
          Module Voltage                                    SSTL 2.5
          Error Detection Method                            None
          Refresh Rate                                      Normal (15.625 us), Self-Refresh
        Memory Timings:
          @ 133 MHz                                         2.5-3-3-6  (CL-RCD-RP-RAS)
          @ 100 MHz                                         2.0-2-2-5  (CL-RCD-RP-RAS)
        Memory Module Features:
          Early RAS# Precharge                              Not Supported
          Auto-Precharge                                    Not Supported
          Precharge All                                     Not Supported
          Write1/Read Burst                                 Not Supported
          Buffered Address/Control Inputs                   Not Supported
          Registered Address/Control Inputs                 Not Supported
          On-Card PLL (Clock)                               Not Supported
          Buffered DQMB Inputs                              Not Supported
          Registered DQMB Inputs                            Not Supported
          Differential Clock Input                          Supported
          Redundant Row Address                             Not Supported
        Memory Module Manufacturer:
          Company Name                                      Samsung
          Product Information                               [URL="http://www.samsung.com/Products/Semiconductor/DRAM/index.htm"]SAMSUNG Semiconductor[/URL]
      [ DIMM2: Samsung M3 68L1713DTL-CB0 ]
          Serial Number                                     F201FA4Ch
          Module Width                                      64 bit
        Memory Timings:
    --------[ Debug - PCI ]-------------------------------------------------------------------------------------------------
        B00 D00 F00:  VIA VT8751(A) ProSavage P4M266(A) Chipset - System Controller
          Offset 00:  06 11 48 31  06 00 30 22  00 00 00 06  00 08 00 00
          Offset 10:  08 00 00 E0  00 00 00 00  00 00 00 00  00 00 00 00
          Offset 20:  00 00 00 00  00 00 00 00  00 00 00 00  06 11 48 31
          Offset 30:  00 00 00 00  A0 00 00 00  00 00 00 00  00 00 00 00
          Offset 40:  00 18 88 80  82 44 00 00  18 99 88 80  82 44 00 00
          Offset 50:  E8 5F EF 88  64 85 10 10  66 00 08 08  10 10 10 10
          Offset 60:  0A 2A 00 20  E6 99 00 27  CF 4D 86 50  40 04 00 00
          Offset 70:  82 C8 00 01  01 01 10 00  01 00 00 00  00 00 00 00
          Offset 80:  00 61 00 00  C0 B8 00 00  02 00 01 00  00 00 00 00
          Offset 90:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
          Offset A0:  02 C0 20 00  07 02 00 1F  04 01 00 00  2D 92 04 00
          Offset B0:  78 AC 10 9B  40 00 E8 FF  68 00 00 00  00 00 00 00
          Offset C0:  01 00 02 00  00 00 00 00  00 00 00 00  00 00 00 00
          Offset D0:  00 00 00 00  00 00 00 08  22 00 22 00  70 38 02 00
          Offset E0:  00 00 00 18  00 00 89 00  40 00 00 00  00 00 00 00
          Offset F0:  00 00 00 00  00 00 81 00  00 00 00 00  00 00 00 00
        B00 D01 F00:  VIA AGP Controller
          Offset 00:  06 11 91 B0  07 01 30 22  00 00 04 06  00 00 01 00
          Offset 10:  00 00 00 00  00 00 00 00  00 01 01 00  F0 00 00 00
          Offset 20:  00 E6 F0 E7  00 E4 F0 E5  00 00 00 00  00 00 00 00
          Offset 30:  00 00 00 00  80 00 00 00  00 00 00 00  00 00 0C 00
          Offset 40:  83 47 00 44  24 72 00 00  00 00 00 00  00 00 00 00
          Offset 50:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
          Offset 60:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
          Offset 70:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
          Offset 80:  01 00 02 02  00 00 00 00  00 00 00 00  00 00 00 00
          Offset A0:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
          Offset B0:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
          Offset C0:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
          Offset D0:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
          Offset E0:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
          Offset F0:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
        B00 D10 F00:  VIA VT83C572 PCI-USB Controller
          Offset 00:  06 11 38 30  07 00 10 02  80 00 03 0C  08 20 80 00
          Offset 10:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
          Offset 20:  01 D0 00 00  00 00 00 00  00 00 00 00  06 11 38 30
          Offset 30:  00 00 00 00  80 00 00 00  00 00 00 00  0B 01 00 00
          Offset 40:  40 12 03 00  00 00 00 00  00 0B 00 00  00 00 00 00
          Offset 60:  10 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
          Offset 80:  01 00 C2 FF  00 00 00 00  00 00 00 00  00 00 00 00
          Offset C0:  00 20 00 00  00 00 00 00  00 00 00 00  00 00 00 00
          Offset F0:  00 00 00 00  00 00 00 03  00 00 00 00  00 00 00 00
        B00 D10 F01:  VIA VT83C572 PCI-USB Controller
          Offset 20:  01 D4 00 00  00 00 00 00  00 00 00 00  06 11 38 30
          Offset 30:  00 00 00 00  80 00 00 00  00 00 00 00  03 02 00 00
        B00 D10 F02:  VIA VT83C572 PCI-USB Controller
          Offset 20:  01 D8 00 00  00 00 00 00  00 00 00 00  06 11 38 30
          Offset 30:  00 00 00 00  80 00 00 00  00 00 00 00  0C 03 00 00
        B00 D10 F03:  VIA USB 2.0 Enhanced Host Controller
          Offset 00:  06 11 04 31  07 00 10 02  82 20 03 0C  08 20 00 00
          Offset 10:  00 00 00 E8  00 00 00 00  00 00 00 00  00 00 00 00
          Offset 20:  00 00 00 00  00 00 00 00  00 00 00 00  06 11 04 31
          Offset 30:  00 00 00 00  80 00 00 00  00 00 00 00  05 04 00 00
          Offset 40:  00 00 03 00  00 00 00 00  A0 10 00 89  00 00 00 00
          Offset 50:  00 5A 00 80  00 00 00 00  04 0B 88 88  53 88 00 00
          Offset 60:  20 20 01 00  00 00 00 00  01 00 00 00  00 00 00 C0
        B00 D11 F00:  VIA VT8233A/VT8235 PCI-ISA Bridge
          Offset 00:  06 11 77 31  87 00 10 02  00 00 01 06  00 00 80 00
          Offset 20:  00 00 00 00  00 00 00 00  00 00 00 00  06 11 77 31
          Offset 30:  00 00 00 00  C0 00 00 00  00 00 00 00  00 00 00 00
          Offset 40:  44 00 F8 0B  00 00 00 00  8C 20 00 00  04 00 0A 08
          Offset 50:  81 1D 09 00  00 B0 C3 50  43 00 00 00  00 00 00 00
          Offset 60:  00 00 00 00  00 00 00 04  00 00 00 00  00 00 00 00
          Offset 70:  06 11 77 31  00 00 00 00  00 00 00 00  20 00 00 00
          Offset 80:  20 84 59 00  F2 30 00 00  01 04 00 00  0A 18 00 00
          Offset 90:  F0 1F 02 88  20 C0 0D 00  00 00 00 00  00 00 00 00
          Offset D0:  01 05 01 00  00 00 00 00  00 00 00 00  00 00 00 00
          Offset E0:  00 00 00 00  04 08 00 00  00 00 00 00  00 00 00 00
          Offset F0:  00 00 00 00  00 00 07 00  00 00 00 00  00 00 00 00
        B00 D11 F01:  VIA VT82C571 IDE Controller
          Offset 00:  06 11 71 05  07 00 90 02  06 8A 01 01  00 20 00 00
          Offset 20:  01 DC 00 00  00 00 00 00  00 00 00 00  06 11 71 05
          Offset 30:  00 00 00 00  C0 00 00 00  00 00 00 00  FF 01 00 00
          Offset 40:  0B F2 09 05  18 1C C0 00  20 20 20 20  FF 00 B6 B6
          Offset 50:  07 07 17 F1  0C 03 00 00  A8 A8 A8 A8  00 00 00 00
          Offset 60:  00 02 00 00  00 00 00 00  00 02 00 00  00 00 00 00
          Offset 70:  02 01 00 00  00 00 00 00  02 01 00 00  00 00 00 00
          Offset 80:  F8 2E 34 02  00 00 00 00  00 00 00 00  00 00 00 00
          Offset D0:  06 00 71 05  06 11 71 05  00 00 00 00  00 00 00 00
        B00 D11 F05:  VIA AC'97 Enhanced Audio Controller
          Offset 00:  06 11 59 30  01 00 10 02  50 00 01 04  00 00 00 00
          Offset 10:  01 E0 00 00  00 00 00 00  00 00 00 00  00 00 00 00
          Offset 20:  00 00 00 00  00 00 00 00  00 00 00 00  06 11 61 41
          Offset 30:  00 00 00 00  C0 00 00 00  00 00 00 00  0C 03 00 00
          Offset 40:  01 CC 00 00  00 00 00 00  00 00 00 00  00 00 00 00
          Offset 80:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
          Offset C0:  01 00 02 06  00 00 00 00  00 00 00 00  00 00 00 00
          Offset D0:  01 00 02 06  00 00 00 00  00 00 00 00  00 00 00 00
        B00 D12 F00:  VIA VT6102 Rhine II Fast Ethernet Adapter
          Offset 00:  06 11 65 30  07 00 10 02  74 00 00 02  08 20 00 00
          Offset 10:  01 E8 00 00  00 10 00 E8  00 00 00 00  00 00 00 00
          Offset 20:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
          Offset 30:  00 00 00 00  40 00 00 00  00 00 00 00  0B 01 03 08
          Offset 40:  01 00 02 FE  00 00 00 00  00 00 00 00  00 00 00 00
          Offset 50:  00 00 80 04  00 00 00 00  00 00 00 00  00 00 00 02
        B01 D00 F00:  nVIDIA RIVA TNT2 M64 Video Adapter
          Offset 00:  DE 10 2D 00  27 00 B0 02  15 00 00 03  00 F8 00 00
          Offset 10:  00 00 00 E6  08 00 00 E4  00 00 00 00  00 00 00 00
          Offset 30:  00 00 00 00  60 00 00 00  00 00 00 00  0B 01 05 01
          Offset 40:  00 00 00 00  02 00 20 00  07 00 00 1F  04 01 00 1F
          Offset 50:  01 00 00 00  01 00 00 00  CE D6 23 00  0F 00 00 00
          Offset 60:  01 44 01 00  00 00 00 00  00 00 00 00  00 00 00 00
    --------[ Debug - Video BIOS ]------------------------------------------------------------------------------------------
        C000:0000  U.Z.K7400.L.w.VIDEO ......U...IBM VGA Compatible......&.06/27/01
        C000:0040  ..............................PMIDX.[............[.NV....(.....
        C000:0080  ........m.........P...q(a.........b.........?>76...^............
        C000:00C0  ........................................PCIR..-.........Z.......
        C000:0100  NVIDIA TNT2 Model 64 VGA BIOS...................................
        C000:0140  .................Version 3.05.00.10B25 ...Copyright (C) 1996-200
        C000:0180  0 NVidia Corp...........e............n............z........z....
        C000:01C0  ....z........z........z........z........y..h..0y..h..0z........y
        C000:0200  ..h...z........z.....%. z.....b.Az........z.....W..cn...........
        C000:0240  .n.........b.Az..h.....z........z........n..h.........x..8..x...
        C000:0280  .?x..(..x..3..x..!..x..+..x..,..qqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqq
        C000:02C0  qqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqq
        C000:0300  qqqqqq.]....xi....`m....Hq.....}................p.....X.........
        C000:0340  ..P."."...%.%.VESA................Riva TNT......................
        C000:0380  .....Chip Rev B1.....................................@.@. . .h.h
        C000:03C0  .j.l...9.....`2...f..Pf...f..Wf.Xf.......f...f..)....t....f.a.`.
    The names of actual companies and products mentioned herein may be the trademarks of their respective owners.
  2. donkey42
    donkey42 plank
    yes, but if you are matching new RAM with existing RAM it will only run the top speed of your existing RAM, so, it would run at PC2100 (266Mhz), but you could buy PC3200 (400Mhz) but it will only run at 266Mhz because of your existing RAM
