Home built problems (never seen before)
Discussion in 'General Hardware' started by fairlo, Mar 17, 2008.
  1. fairlo
    fairlo Geek Trainee
    Hi all
    to date i have built around 100 pc without problems but i have an issue with a current build and can't seen to work it out.
    the system spec is:
    2.4ghz Core2Quad
    Asrock motherboard
    2x1GB 800MHz DDR2
    Geforce 8800GS
    The system installs windows xp pro fine with no problems or errors, however after the install windows boots up fine then when i try to install the onboard drivers or the graphics card driver all i get is set up errors. If i try to install the drivers through the update driver option from device manager it tries but then says it can't copy the files. I have tried working memory and two different hard drivers and get the same problems. I even install Wip xp 64bit and it did the same. It also won't install any software at all.
    Any help would be greatly appriciated as i am out of ideas
    thanks in advance for your help
  2. Ghostman 1
    Ghostman 1 Mega Geek
    Is this 32 bit or 64 bit ? Is the hard drive IDE or sata ?
