hi guyz. im wondering because yesterday my v card got busted (i think) because
every time i access a game my pc shuts off or sometimes the monitor only shuts off and i can hear some noises from the game...
i searched and searched in the internet how to fix this problem but many came up with replacing your v card so i did,but in fact my new v card "radeon 9550"
works fine but after 2 hours the monitor again shuts off unexpected the symptoms again showed up...
until i installed a speed fan and discovered my pc is heating up to temp:60C even if there is no active application, and in fact i have 2 fans blowing towards the cpu and i removed the cpu skin..but the problem persists..when i played "warrock" with my new v card it turned out well but after a few minutes the monitor again shuts off and i heard sounds of that game i pressed ctrl+alt+del luckily the monitor again starts back up because warrock has been ended using task manager the same thing happens with my old v card..
after a few minutes i executed again warrock and opened
the speed fan(application)it went temp:70C after that it gone busted and i tried to view the task manager under the performance tab i saw 100% Cpu usage..
guyz i was wondering what made the heat so intense even if i had only a single application running and last week even i accessed the internet chatting with yahoo and executed warrock at the same time it turned out well and no signs of computer failure and back then it is my old v card..
my processor is pentium 4 3.00ghz
v card old: radeon 9200SE 128mb
v card new: radeon 9550 256mb
Ram: 768mb
my v slot is AGP
plz help me guyz there's an upcoming tournament here on our country i want to train ..:(
Ram: 768mb
my v slot is AGP
