QuiPetMonDe
Geek
I need help on connecting to the web on my new first build pc.
I just put xp pro on and i just put a few drivers on but when i connect my ethernet cable to my cable modem, then to my pc ethernet port nothing happens, i want the computer to automatically detect the connection but nothing happens, can anyone help?
I am using the built in ethernet on my motherboard, the drivers are installed.
EDIT: Every time i click IE to run it i keep getting the open with box and the only options are notepad and WINDOWS picture and fax viewer.
