Lan adapter doesn't work!
Discussion in 'Networking and Computer Security' started by antivirus, Oct 3, 2009.
  1. antivirus
    antivirus Geek Trainee
    Hi everybody,
    I have a laptop (HP 6735s). I used to browse the Internet with it but now the LAN adapter just doesn't work. My OSs (both Windows and Linux) tell me that the adapter works fine but the cable is unplugged (although the cable is Plugged and no LEDs light or blink in both laptop and router). I had experienced a similar behavior with the laptop in the past, but the problem vanished by itself within an hour. Now the adapter doesn't work since 29th September!
    Is the adapter burnt out and/or should I give it to technical service?
    P.S. Sorry for my bad English!
  2. RHochstenbach
    RHochstenbach Administrator
    Welcome to HWF :)
    The best thing to do first is to check the cable itself. Do you have a spare network cable to test if that does work?
  3. antivirus
    I don't have spare network cable. I tried with 2 "regular" cables - don't work on the laptop but they do work on my old PC. Probably the problem is not in cable.
  4. RHochstenbach
    If the cables work fine with other computers, then the LAN adapter is indeed broken.
  5. BoBBYI986
    BoBBYI986 Geek
    have you tried another port on the routers switch? tried hard resetting your router?
  6. Dracos
    Dracos Geek
    are u sure that the cable is straight, not cross?
  7. antivirus
    I've been using this cable for more than 3 years and suddenly the connection died. The cable is for router->computer usage (I think) because that's how I used it with no problems. As RHochstenbach said probably the LAN adapter is broken. I consider going to technical service...
  8. macbeton
    macbeton Guest
    Just use wireless! :)
