lowering mulitlplier, does it help?
Discussion in 'Overclocking & Cooling' started by halfpipehippie, Aug 8, 2006.
  1. halfpipehippie
    halfpipehippie Geek Trainee
    ok a few question, should i leave the mulitplier at max of 9, or should i lower it and raise FSB? its at 9 by default and what is hypertasnport and and what will happen if i change it? also how can i tell if my system is unstable when im testing?and finally i dont know how to Increase memory latency timing at all, idk where that feature is in my BIOS. thanks
  2. vol7ron
    vol7ron Guest
  3. Big B
    The reason people do this is to achieve a faster FSB, and gain more performance for the same speed. Since the HTT/FSB is linked to the RAM, you'll increse the RAM's speed too, which will eventually require you to loosen the timings. Check your motherboard manual, but you'll want to look for 'Frequency and Voltage' from the main menu. If not that, you may want to see if there's a Core Cell listing. Again, consult your manual.
    When overclocking, your two best friends are [google]Memtest[/google] and [google]Prime95[/google]. Memtest is run off a floppy or CD (just open the .ISO file with something like Nero and burn it), so set BIOS to boot off the floppy or CD and let it run for several hours to give the RAM a good beating. If you start coming up with errors, then you'll need to loosen the timings, reduce the speed, or increase the RAM voltage a little.
    After you've found a stable speed, then you'll want to use Prime95 in Windows. Let it run for at 24 hours straight. If you don't get any errors, then the CPU should be fine at that speed. If not, then you either need to increase the voltage a little or look at better cooling. There's also the CPU's limit as to how fast it can go, period.
    You'll need to go slowly, like 5MHz increments at a time, test, tweak, and test again. This isn't something you'll simply crank up the speed on and go on your merry way. You are running things out of spec and out of warranty.
    Hypertransport is a low-latency interconnect standard, developed by the HyperTransport consortium, which AMD is part of. AMD has used it to replace the FSB on the Athlon64, in part because of the speed and lower latency.
  4. halfpipehippie
    see the thing is i dont have all the features in my bios because of AMD 64, i dont have a FSB speed or a memory speed, so i cant follow the tutorial correctly
  5. zeus
    zeus out of date
    I haven't got clue about overclocking it but Ive always used memtest86 and prime95 to test my overclocks.
    If you can run them both for a least 12hrs with no errors then you should be OK. But saying that Ive still run into problems with certain programs even with no errors from these two programs so its worth trying out the programs you use often.
