Messenger Problems
Discussion in 'Networking and Computer Security' started by fsbee, Oct 18, 2006.
  1. fsbee
    fsbee Geek
    I've added a belkin G router to my system,and now have problems,Network connection is fine using router or not --but as soon as I use router MSN messenger wont work (some may say good--not my daughter) with lead straight in network port no problem, but as soon as router in the loop either wired or wireless then MSN just wont work, every other connection to internet fine. Have top AOL package(that allows networking). Has any body any ideas.
    Thanks
  2. Karanislove
    Do you have a firewall? If yes, then check the settings in it.
  3. joliser
    joliser Geek Trainee
    Try configuring your router for port 1080 tcp and I believe udp as well... in and out.
  4. fsbee
    fsbee Geek
    Think I might have solved it,Turned off all firewalls-no difference.Got onto belkin support,35mins later altered MTU value to 1400, No idea what that is or even how I got to the window that displayed it. Keeping everything crossed until daughter contacts her buddies!
    Really grateful for suggestions-thankyou
