I have an E7200 with on this board: Newegg.com - GIGABYTE GA-EP45-UD3P LGA 775 Intel P45 ATX Intel Motherboard - Intel Motherboards I am looking to get HS so I can do some moderate OC'ing. I was looking at this Newegg.com - ARCTIC COOLING Freezer 7 Pro 92mm CPU Cooler - CPU Fans & Heatsinks but i am VERY concerned about it fitting since the stock HS BARELY fits already (had to trim it a little to make it fit!). Anyone know if this will/should fit? or have a better suggestion? Thanks for the help!
in the link you can see the blue heatsinks for the mobo would be touching the current stock fan plastic (both the one saying ultra duralbe and gigabyte).
