Need help for IEEE socket/cable
chanduhyd4u
Geek Trainee
Hi
This is my first post. The following are my system hardware details.
1. first quesiton is I would like to upgrade it to 256MB ram , 80 GB hard disk, I am not sure if it its possible with this hardware
2. I want to have on IEEE socket and cable to copy movies recorded with handycam to my system.
Please let me know if with the following hardware configuration its possible to use IEEE.
Anticipating the best and early answer.
Please let me know if you need more details.
Thanks
OS Information:
PropertyValue
OS Name Microsoft Windows 2000 Professional|C:\WINNT|\Device\Harddisk0\Partition1
Service Pack 4.0
OS Manufacturer Microsoft Corporation
Windows Directory C:\WINNT
Processor:
PropertyValue
Current Clock Speed 734
Description x86 Family 6 Model 8 Stepping 6
Manufacturer GenuineIntel
Name Intel Celeron processor
Memory (RAM):
PropertyValue
Bank Label RAS 3 & 2
Capacity 134217728
Total Memory Deteced in Hardware: ~128 MB
Memory Reported to Operating System: 126MB
Disk Drives:
PropertyValue
Description Disk drive
Manufacturer (Standard disk drives)
Model ST320413 A SCSI Disk Device
Media Type Fixed hard disk media
Size 20020331520 (~19 GB)
Number of Partitions 4
Installed Printers:
PropertyValue
Name Microsoft Office Document Image Writer
Port Name Microsoft Document Imaging Writer Port:
Driver Name Microsoft Office Document Image Writer Driver
Motherboard:
PropertyValue
Manufacturer TIGA
Model
Name Base Board
Part Number
Product 810
Serial Number 00000000
Version 1.0
BIOS:
PropertyValue
Manufacturer American Megatrends Inc.
Name Default System BIOS
Release Date 20010404******.******+***
Version TI-810+S Ver 1.07 (010404)
Monitor:
PropertyValue
Description Default Monitor
Name Default Monitor
Screen Height 600
Screen Width 800
Keyboard:
PropertyValue
Description PC/AT Enhanced PS/2 Keyboard (101/102-Key)
Pointing Device:
PropertyValue
Name Microsoft PS/2 Mouse
Sound Card:
PropertyValue
Manufacturer Analog Devices, Inc.
Description SoundMAX Integrated Digital Audio
Device ID PCI\VEN_8086&DEV_2415&SUBSYS_414411D4&REV_02\3&13C0B0C5&0&FD
Video Card:
PropertyValue
Adapter Compatibility Intel Corporation
Adapter RAM 4194304
Description Intel(r) 82810 Graphics Controller
Installed Display Drivers i81xdnt5.dll
Driver Version 5.12.01.2636
Driver Date 7/14/2000 6:08:20 PM
Video Mode Description 800 x 600 x 16777216 colors
DirectX Installation:
PropertyValue
Version 6.01.09.0727
Modem:
PropertyValue
Network Adapters:
PropertyValue
Description NDIS 5.0 driver
Description RAS Async Adapter
Description WAN Miniport (L2TP)
Description WAN Miniport (PPTP)
Description Direct Parallel
Description WAN Miniport (IP)
Description Microsoft TV/Video Connection
External Ports:
PropertyValue
External Reference Designator Serial Port A
External Reference Designator Serial Port B
External Reference Designator Parallel Port
External Reference Designator Keyboard
External Reference Designator PS/2 Mouse
External Reference Designator Floppy
External Reference Designator IDE-1
External Reference Designator IDE-2
External Reference Designator USB
Expansion Slots:
PropertyValue
Slot Designation PCI1
Slot Designation PCI2
Slot Designation PCI3
Slot Designation PCI4
it's not a problem with upgradeing your RAM because your M/B supports up to 512Mb :good: (256Mb in each slot), not sure about HDD you may be restricted to 50Gb (unless you flash your BIOS)
i don't see a problem using IEEE with your setup
hope someone can give you more input about HDD
Hey thanks for the quick response.
Could you give more details on flashing BIOS?
and where does IEEE socket fits in is it in PCI or something else? Sorry if its a dumb qn.
Thanks
hi, more info on BIOS flashing is available here or your M/B manufactures website, but be VERY VERY carefull flashing your BIOS (cos a power failure during a flash will probably kill your M/B, just be carefull)
as for IEEE you just need a USB cable and software
Hi Thanks for the reply
I believe IEEE 1394 is not the USB but it will hv a different socket and cable( Firewire Cable/i.link cable). and i want to know if it fits on my motherboard .
