Need of Help with Firefox
Discussion in 'General Software' started by AWOL Elendil, Dec 20, 2006.
  1. AWOL Elendil
    AWOL Elendil Geek Trainee
    My browsers play some audio, but not all of it. for example, Runescape, from jagex, is as clear as a whistle, but embedded audio and audio from embedded video isn't even detectable. Need help!
    If it helps with determining the problem, I can even hear audio from files opened with my browsers. It's just stuff embedded on websites...
    HELP PLEASE!
  2. Addis
    Addis The King
    What type of plugins are you using? Flash movie plugin or actual Windows media plugin?
  3. AWOL Elendil
    whatever comes with preinstalled on firefox 2.0. I also had the same problem with the previous incarnations of firefox 1.5 version, so i'm not sure. A friend said it might be a virus, but nothing I have on my PC has found it yet, though it is free software...
    Youtube and GoogleVid do not work, either.
  4. AWOL Elendil
    uh... neither Adobe Flash player or WMP work.
  5. donkey42
    donkey42 plank
    it could be a codec problem, try downloading and installing K-Lite codec pack
  6. DaRuSsIaMaN
    DaRuSsIaMaN Geek Comrade
    that sounds like some serious problem with windows...
  7. AWOL Elendil
    like what?
  8. Karanislove
    Most probably the problem is [link=http://www.hardwareforums.com/need-help-firefox-15962/#post104272]This[/link]
  9. AWOL Elendil
    ddin't work...
