need sound advice...
Discussion in 'Sound Cards and Speakers' started by Dragonfire, Nov 30, 2005.
  1. Dragonfire
    Dragonfire Geek Trainee
    Hi, If I'm playing my sounds thro' the hi-fi is it still affected by the sound card i'm using? Will upgrading the card make my music noticably different? Not even sure what i have installed as standrd...
  2. Addis
    Addis The King
    Most soundcards now are good enough to be played at a high quality, so even onboard sound will sound good.
    If you do have problems, you always have the option of a cheap PCI sound card which should do very well.
