Hello everyone
I am having problems with my PC booting.
I have windows XP and the motherboard is a Soltek 400C.
This is the story so far.
About a week ago I had problems with my PC booting up. The screen was black and the PC did not appear to be booting at all. All drives appeared to show activity when initially being checked at start up. ( ie the light on each drive flashed )
I restarted it manually and after a couple of tries it started okay.
The problem got worse and I now have to manually restart 6 or 7 times.
I tried system restore and last good configuration but no joy.
Sometimes it will go through the initial stages firstly coming up with the Graphics card details and then freezing when it shows the usual data text etc etc.
I decided to reformat the hard drive and re load windows but this had no effect.
Somebody at work said it could be the graphics card so i bought a new one, but it is still doing the same thing. Checked all wires in drives etc which are okay.
I reset the CMOS by shorting the pins and again this had no effect.
I have checked the memory using windows microsoft program and this shows okay.
I am now at a loss what to do next.
Is there any checks I can do in the BIOS etc or anything else I should try.
I would be really grateful for any suggestions. Thanks in advance
dlh
dlh
