Pc-problem
fantastickmath
Geek Trainee
I have a PC with this information:
  • Os: windows 7- 32 biti
  • CPU: Intel(R) Celeron(R) D CPU 3.06 GHz
  • RAM: 4.00 GB (useable 2.94 GB)
  • Adapter: Nvidea Geforce 9400 GT :
  • Total memory grafics: 2271 MO
  • Memory video dedicated: 1024MO
  • Memory video syste: 0 MO
  • Shared Mmory: 1247b MO
The problem with this PC is I can not even watch a video-clip on youtube because it's so abruptly(a dont know the exact words- my english is weak) ... so.. the videoclip intrerupt every seconds.... The samesituation is with the game .... even counterstrike 1.6 are functionaly abruptly ... :( .... i dont know why it function like that .....
I mention i did not have viruses .... (i use kaspersky 2012 ) ...
The problem with youtube is your adobe flash, this happens to everyone.. Adobe has not perfected a flash player yet that works right.. Next when playing ANY type of video games, you will need a Large video card...you might want to check your video card..
Do you have onboard video OR you are using a Card ? If you are using a card with default VGA settings, then that is your problem..
What is the make and the model of your card.? You probably just need the right driver ...
OK, look at the back of the computer .... Now look to see if your Monitor plugin is at the top with all the other plugins or is it separate and more to the bottom ..
I see in your description you have a Nvida Gforce 9400 Gt, IS this right ? Where did you get this info ? If this is true, then you have a Video card...
You just need the drivers to make it work right..
bottom
yes... im sure 100%....
but that VGA what mean ? it's need a driver?
lts nvidea driver for my pc :confused: .... i have my nvidea driver newest than this driver....(version 306.23 the newest version of this driver)
if you ware that my driver is not compatibil ....i assure you that it 100 % compatibil....
so?
I have installed on my pc nvidea 306.23 ... it's a compatible version and the newest ... but i also have something on my pc ... VGA and i dont know what it's !!!! ..... It's not really important ... i only want to know why my pc are function so abruptly (youtube-clip and pc games...) ... i have some friend that they own a pc weaker than mine and they dont have such problems....
Check your version of Adobe flash to there's ... All problems like hanging and lagging is from Adobe flash... As far as Video games, Most problems there come from Vider card...
