Power Connection to Mobo Question
Discussion in 'CPU, Motherboards and Memory' started by erichpeterson, Sep 17, 2009.
  1. erichpeterson
    erichpeterson Geek Trainee
    Hi,
    I just completed building a new computer. After everything was installed I powered the computer on for the first time. I heard things spinning but the BIOS did not appear. I reopened the box and saw the CPU fan was not turning. I found I had plugged in the 2x12 power connector but not the 2x4. I plugged it in and this time the BIOS came up.
    My question is: did I possibly damage the CPU and/or the GPU?
    Thanks,
    Erich
  2. BoBBYI986
    BoBBYI986 Geek
    if your system bios posts your all good. wouldn't worry about it.
