Power Supply Upgrade
PeacePlease
Geek Trainee
need to see the back of your case, and the way it bolts ... Also make sure new power supply is the same on the main pin... 20/24...
Yes it will fit...
The power supply unit in today's modern computer assumes a role probably more critical than any other single component in your system.
A poor PSU can also cause other components to fail in your computer.
The right Brand names = Quality
Some approved Brand names follow...
Seasonic - any model
Corsair - any model
Thermaltake - "Toughpower" series only
Coolermaster - "Real Power Pro" series only
PC Power & Cooling - any model
Silverstone - any model
Unless you are into some serious gaming a 600 watt or higher will take care of your needs.
If you are a serious gamer a 750 Watt, or a little higher will be all that you would need.
It should work. The only company I've heard to use a funny wiring layout is Dell, and I'm not so sure they do that anymore, but don't quote me.
A quality 450-500W should be fine unless you plan on getting some high-end GeForce or Radeon to drop in that thing. Even then, some 500-550W units can do it if the +12V has enough juice to sufficiently power the beast.
