hiya pc people...
i really need some help with a new pc i have just bought.
its a new/refurbished dell dimension 3100c which i purchased in the hope that i will be able to use if for music production as well as for internet usage etc.
to get to the point,,,,as soon as i set it up,following the norm procedure etc...i installed my blueyonder disc for my internet and at end of installation i got a macafee msg saying it had found and supposedly cleaned a trojan..and there were then error messages on the pc at end of installation of the disc.i have used this disc before and never had any probs...and it had installed the drivers etc for blueyonder internet which i use as homepage etc.
but....soon as i look on homepage,display of text is really small (xp by the way) on the screen which ive never had before also,as my optiplex before was fine with all display,graphics etc...also the internet pages have a 2 inch gap down either side,homepage included.
this is first apparant problems i was aware of,and not being an expert much at all with all features of xp and or pc terminology etc,i had no idea what could be wrong..please help...i phoned dell,they told me to restore to fac settings,so i did but makes no difference,also i instantly registered with macafee online,but then the pc will not let me loggin or change my password to the macaffee site,...and i managed to change text size for some pf the display on advanced settings in the "display" option in comtrol panel,but it still isnt really what it should be ...really,and still this annoying 2 inch gap on sides of pages on net...and its running really slow,even slowere than my much smaller spec and p3 optiplex ...and main reason i bought it is cos its a p4,should be faster,3 ghx processor etc..also it has frozen a bit,not loading pages properly etc..the list goes on.
i really need it for work etc,and dell are now saying they want me to reinstall all software etc..so theyve sent me a bunch of discs...and say theyll go through it with me.. i just want normal xp,running smoothly as it should on an as new pc like this..with no graphic problems,text size,internet display,and possibly trojans or spyware on it.. i hope some1 knows about this and can please help me to some degree..im despeerate here..:x:
