Problems with printing format
Discussion in 'General Hardware' started by efx2003, Jun 5, 2006.
  1. efx2003
    efx2003 Big Geek
    When I print out a web site. The printer prints everything fine but on the right margin of the paper there is about 10% of the print missing. Does anybody what can be done to fix this problem. Please Help. Thank You.
  2. donkey42
    donkey42 plank
    the reason for this is: the webpage you are printing is wider than the actual page width, your print driver software may have a "zoom" feture, try setting it to about 90% and see what happens, if still not displayed correctly try reduceing the zoom until print is correct
  3. Addis
    Addis The King
    It happens, you may be able to find a printer friendly version on the site. If not try to edit out the stuff you don't want.
  4. donkey42
    donkey42 plank
    yeah, if you can't figure out the zoom thing, try that
  5. Karanislove
    Before printing any page, remember 1 thing in your life.........always look at its print preview first.......Its under file selection.
    The thing which you will see in there will be the one you will get from your printer. If you see that data is missing on the corners then use landscape paper style.
    Always use print function from the file menu because it shows you how many pages you will gona print. There are some websites, who has lots of stuff not useful for you and you will end up with 60 pages, where you want only 10 pages from it.
  6. Matt555
    Matt555 iMod
    I know Firefox has an option in print preview called "Shrink to Fit" which I think makes the website you're printing fit onto the specified size of paper.
