Problems with XP startup
Discussion in 'Windows OS's' started by thunder36, Jan 12, 2005.
  1. thunder36
    thunder36 Geek Trainee
    Can anyone tell me what this erroe message means that i get when i try to install XP:
    File Vga.sys caused an unexpected error (4096) at line 3138 in d:\xpclient\base\boot\setup\setup.c.
    I tried it a couple times and it gets hung up at the same spot. Please help.
  2. Dave35k
    Dave35k H4ck3r
    i would of thought vga.sys was something to do with graphics drivers or something like that. is it a copied version of windows, and have you formatted it or upgrading (i would format) + whats ya pc spec. hope this helps post backe Dave :good:
  3. thunder36
    Comp Specs: Everything is brand new, just assembled monday. And yes, I am using a copied windows disc. Could this be the problem??
    Intel LGA 775 Pentium 4 530 3.0 GHz, 800MHz FSB, 1MB L2 Cache, Hyper Threading Technology
    MSI "915P NEO2 PLATINUM 7028-020" 915P Chipset Motherboard For LGA 775 CPU
    MSI nVIDIA GeForce 6600 Video Card, 128MB DDR, 128-Bit, DVI/TV-Out, PCI-Express, Model "NX6600-TD128E"
    Western Digital 80GB 7200RPM IDE Hard Drive, Model WD800BB,
    Lite-On Black 52X32X52 CD-RW Drive, Model LTR-52327S,
    NEC 16X Double Layer DVD±RW Drive, Black w/ Software, Model ND-3520A
    SPECTEK 240-Pin 512MB DDR2 PC2-4200, Model PM64M6416U26AD2F-37E
  4. syngod
    syngod Moderator
    Yeah if it's a copied disc it sounds as though that file is corrupted.
    I'd try using the actual cd and it should alleviate the problem.
  5. Dave35k
    Dave35k H4ck3r
    yea using a copied version cud be a problem try installing the compact version and this might bypass this particular file if not try and get a different copy hope this helps Dave :good:
