Radeon HD2600Pro AGP OK?
manic49er
Geek Trainee
I have a PC with -
Asus A8V Deluxe motherboard (with Via chipset)
Athlon 4000+ processor
XFX Geforce 6800GT
1Gb Ram
Since I can't get the 6800GT grfx card to work properly with this Mobo (supposedly known issue with chipset "sometimes") I'll need to buy another one. The Mobo only has AGP connector no PCIE which will severely limit my options nowadays ;+(
I saw a Radeon HD2600Pro clearanced for $79.99 (reg $150) how would this grfx card be? The computer has a tuner card (unknown vendor) and is running Windows XP Media Center.
Is this about the best I can hope to get nowadays?
(as I'm leery of losing money on restocking fees on any more Nvidias)
Is it at least comparable to the 6800GT?
Will it handle tuner card ok (in otherwords for pvr and other multimedia uses?)
Is the cost OK?
As my other PC died again for the 2nd time in ~ 5 weeks (1st time Boot Drive died physically), 2nd time Windows XP corrupted so won't boot (on a new WD160 Gb HD) so I'm debating whether I should just give up on it and move over to this other PC I won 3 years ago (unfortunately, as is, found had grfx card issues I couldn't afford to fix then). The old PC has an FX5200 Cinema which probably wouldn't be worth putting in the newer PC nowadays (tho I don't play newest games, I'm more into retrogaming, however I would like to run a Future Pinball emulator which I suspect overtaxes this card (as I would think a 2.6GHz Mobo would be OK)
Regards,
manic49er
Well get the biggest 2600 you can find. I have one that is PCI-E.
Here's the specs. After viewing this you may want to upgrade that mobo ang go with pci-e. You WILL notice a large difference!
Field Value
Graphics Processor Properties
Video Adapter ATI Radeon HD 2600 XT (RV630)
BIOS Version 010.052.000.000.025687
GPU Code Name RV630
PCI Device 1002-9588 / 1462-0981
Transistors 390 million
Process Technology 65 nm
Die Size 153 mm2
Bus Type PCI Express x16 @ x16
Memory Size 512 MB
GPU Clock 844 MHz (original: 850 MHz)
RAMDAC Clock 400 MHz
Pixel Pipelines 4
TMU Per Pipeline 2
Unified Shaders 120 (v4.0)
DirectX Hardware Support DirectX v10
Pixel Fillrate 3376 MPixel/s
Texel Fillrate [ TRIAL VERSION ]
Memory Bus Properties
Bus Type GDDR4
Bus Width 128-bit
Real Clock 1143 MHz (DDR) (original: 1150 MHz)
Effective Clock 2286 MHz
Bandwidth [ TRIAL VERSION ]
Miscellaneous
Fan Speed 30%
Utilization 0%
Graphics Processor Manufacturer
Company Name Advanced Micro Devices, Inc.
Product Information ATI Radeon™ Desktop Graphics
Driver Download Drivers & Software
Driver Update DriverAgent.com Fix Your Driver Problems Instantly with DriverAgent
