Registry problem
Discussion in 'General Software' started by Jecht, May 19, 2005.
  1. Jecht
    Jecht Big Geek
    i recently read an article out of pcworld to add the "new folder" link to the context menu. well i put what it said, and after that, anytime i tried to open a folder, the command prompt to open up. wtf....i said, so after that, i read how to delte the key, and i did, but now, when i try to open any folder, the "search results" window comes up, the window you use to search for files and folder on the pc. i dont know what to do next, anybody know a fix for this?
    update:
    i just reapplied the old settings...but those were the settings i had backed up after i did added the link to the context menu. so now im stuck on the frist problem. my problem now is , anytime i open a folder, the command prompt appears instead, with the address of the folder for the first line of the prompt.
    Here is the text that i was told would add the command:
    cmd.exe /c md "%1\New Folder"
    this picture is the result i get from opening "any" folder, even on the network
  2. Sniper
    its always a good idea to backup the registry before making any changes or edits.
    ok try this go to my computer then go to tools > folder options > file types (tab) go to folder and file folder then click advanced and set the options to default.
    I've never had this problem so I'm guessing here.
  3. Jecht
    Jecht Big Geek
    i tried doing that, and that is a good idea so i said, why wouldnt it work? so i did it, and instead of opening the command prompt, is opens up the search results page , someething is edited wrong. and as far as backing up the registry, i never edited the registry directly, it was through a menu in file types. :(
    this picture shows the command that are on my context menu filetype window, and the registry location
