replacing motherboard hp a1410n help?
Discussion in 'CPU, Motherboards and Memory' started by loserspearl, Dec 19, 2008.
  1. loserspearl
    loserspearl Geek Trainee
    I have an HP a1410n with a crappy 2.4 singlecore 939 socket motherboard (asus A8N-LA) I want to replace my motherboard with a better asus that has socket am2 or am2+ for a better processor.
    Can you tell me which of their motherboards would fit?? like crosshair2 or anyothers
    ty
  2. Ghostman 1
    Ghostman 1 Mega Geek
    This all depends on your case...And after looking up your PC, I would say that almost any platform would work...
  3. loserspearl
    theres a good 3 inches of room between motherboard and powersupply and then 2 inches between MB and disk drives, so theres plenty of room, really the issue is screw patterns.
    you think a crosshair2 would fit cuz so far thats the best for my money.
    tell me if you need a pic to make a good judgement
  4. Ghostman 1
    You will need a picture of both, the motherboard and the inside of the case.. Most cases will have the ability to run most motherboards, only changing the connection plate..
  5. loserspearl
  6. Ghostman 1
    The motherboards are different in the way they bolt, BUT you should take a look at your case, to see if there are holes where the New Motherboard will bolt..It should work,But if it will not,then just buy a new case...You can buy a case for under $40.00....
