SATA Installation Problems (System Freezing Before Boot)
Discussion in 'Storage Devices' started by achamenes, Jun 6, 2006.
  1. achamenes
    achamenes Geek Trainee
    Hello,
    I just purchased a Samsung 250GM SATA Hard Disk, 3.0Gb/s with a jumper setting allowing for 1.5Gb/s data transfer.
    My motherboard supports 1.5Gb/s SATA.
    So, I just set the jumper properly, connected the hard-disk and everything works fine at the beginning. The system recognizes the name, size and everything but then it suddenly freezes. I attached photos of the screen where it freezes on.
    The motherboard is Asus P5GD2.
    Please let me know if you require further information, and thanks a lot in advance, for any help.
    EDIT: Screens are attached now...
      File size:
      102.2 KB
      156
      File size:
      97 KB
      142
  2. roy92
    roy92 CSS HAXOR
    try removing the jumper
  3. Big B
    What power supply do you have? Make and model?
