Stuttering problem.
Discussion in 'General Hardware' started by Azzurri, Jan 14, 2007.
  1. Azzurri
    Azzurri Geek Trainee
    Hi, this is my first post on these forums.
    Out of the blue, I started having this stuttering problem while I was playing a game. It never happened before, so I closed the game thinking that it was the program, but now its even windows that has been acting this way. My mouse seems to skip across the screen and my music is stuttering. I ran virus/adware scans even registry mechanic to see if they might fix it. Nothing. I decided to restart my pc, and noticed the windows loading screen taking about 4-8 minutes to finish loading. It seems to stutter when applications are being opened or loading content. I have a feeling it might be either my RAM or HD that is the problem.:(
    Thanks for all the help in advance.
  2. Journeyman
    Journeyman Geek Trainee
  3. Azzurri
    Do I Have to burn this to a CD?
  4. donkey42
    donkey42 plank
    yeah, i think you could do with a format & reinstall
  5. Journeyman
    That is correct
  6. NeloForster
    NeloForster Source of Exyphetadolamin
    Windows stuttering and mouse cursor skipping... Windows slow loading...
    Exactly what happened when two of my previous Intel CPU's failed.
    If the problem is your memory, you'd be plagued with more than just stuttering. Worse - no stuttering, just plain errors, restarts, blue screens, and eventually a windows death.
    Like I say, the exact thing happened when my two intel CPU's were imminent to die. Try and find a friend with the same socket CPU and test.
    Do try the HDD and memory tests though, it's a process of elimination.
    Regards,
    Mike
