System problem
Discussion in 'CPU, Motherboards and Memory' started by herghost, Feb 5, 2007.
  1. herghost
    herghost Geek Trainee
    Hi, im having problems with a new system build. Basically I have the geforce 6200 but im not sure this is the problem as I had the same with another graphics card. When I turn on my system first thing it boots fine, however if i reset it via windows then my screen wont come on. I have to hit the reset button on my tower before it does. I have tried everything in my bios and this has happened with a pci and a pci-e card.
    Ive also updated to the latest bios and drivers for motherboard, chipset and graphics card.
    Any idea's anyone?
    Thanks
    dave
    System Specification---05/02/2007 14:27:53
    Asus M2V Mothrboard (Socket AM2)
    Windows
    Windows NT6.0 (Build 6000)
    Internet Explorer
    7.0.6000.16386
    Memory (RAM)
    1535 MB
    CPU
    AMD Athlon(tm) 64 X2 Dual Core Processor 4200+
    CPU Speed
    2197.4 MHz
    Sound card
    Speakers (3- kX 10k1 Audio (353
    Display Adapters
    NVIDIA GeForce 6200 LE (Microsoft Corporation - WDDM) | NVIDIA GeForce 6200 LE (Microsoft Corporation - WDDM) | RDPDD Chained DD | RDP Encoder Mirror Driver
    Screen Resolution
    1280 X 1024 - 32 bit
  2. Big B
    What power supply do you have?
  3. herghost
    A 500w ATX One!
    Full specs:
    ATX 500W Power Supply Unit. Ideal for AMD & Intel P4 systems. Low noise high efficiency Power Supply Unit, with Over Power and Short Circuit Protection. Brand New, Retail Box Packaging with a Mains Power Cable included. Complete with a full 12 months warranty.
    Item Specification
    500W ATX PSU
    2 x fan for quiet running
    500 Watts Continuous power rating
    High efficiency and Low Noise
    Standard ATX specification
    Over Power Protection
    100% full load burn-in
    1.5Kv Hi-Pot Test Pass, FCC CE approved
    2 x Internal 12cm Cooling Fan
    AC input
    230X, 50-60Hz
    Dimensions:
    150 x 86 x 140 (mm)
    PSU connectors:
    4 x Standard four pin power molex
    1 x floppy power
    1 x AMD/P4 power
    1 x ATX 20/24 pin Motherboard power
    1 x SATA Power
  4. Big B
    What brand? Are all power connectors on the motherboard plugged in?
    For clarification, when are you getting the blank screen upon reboot? When the motherboard is POSTing or when it attempts to boot into Windows?
  5. herghost
    Sorry that bit would have helped! Its manufactured by a company called sum and then the exponential sign (kind of a backwards z crossed with an e) Ive tried the board with literally just the cpu, fan, graphics card and knoppix in the cd drive.
    All the power connectors are plugged in, this is about the 20th odd system ive built and been using these psu's for a while, never had a problem with them before.
    Its when i reboot,windows shuts down normally then instead of restarting and posting i just get a 'no signal detected' message on the monitor and my monitor goes into standbye mode. Ive also just tested and the caps button wont activate the light so im wondering if the board is crashing.
  6. Big B
    Okay,
    Here's a couple of things to try: Go into BIOS and manually set your CPU core voltage to 1.35V and then set your RAM voltage to 1.8V.
    That symbol is the Greek letter 'Sigma' by my best guess. I've never heard of the brand, and if it came with your case especially, you'd be better off to purchase a new powers supply. Unfortunately, not all power supplies are equal, and you can't judge a power supply by the wattage.
    I'd try manually setting those BIOS values first, but if they don't work, buy a new 400-450W+ from the likes of Antec, Enermax, FSP/Sparkle/Fortron, Hiper, OCZ, or Seasonic...which are good brands that you should be able to find quite easily. They are not the cheapest out there, but if you're looking on a pure price point, FSP/Sparkle/Fortron or Hiper will probably be the lowest prices.
  7. herghost
    Ok well i tested the psu with my handy kit and there all kicking out exactly what they should, so its not the psu, also to mak sure tried it with a coolermaster 600w and same problem.I tried flashing the bios and that did the trick, untill the pc was powered off. As soon as it was powered on again it would do the same thing. Really winding me up now!
  8. herghost
    anyone? :)
  9. Big B
    Did you manually set the values I suggested? Are they available?
