system32 problem
Discussion in 'General Software' started by skylark4, Jul 31, 2006.
  1. skylark4
    skylark4 Geek Trainee
    my dauthters laptop wont start up she has a blank skreen and a message <windows root>\system32\hal.dll we are at a loss she is running windows xp home ed we have put in the xp cd but no responce help
  2. Karanislove
    Error
    Winnt_root\System32\Hal.dll missing or corrupt:
    Please re-install a copy of the above file.
    CAUSE
    This behavior can occur if any or some of the following conditions are true: • The Default value in the [Boot Loader] section of the Boot.ini file is missing or invalid.
    • Windows XP is not installed in the location specified in the Boot.ini file.
    • The Ntoskrnl.exe file is missing or damaged.
    • The partition path in the Boot.ini file is not set correctly.
    • General hardware failure.
    RESOLUTION
    To resolve this issue, use either of the following methods.
    Method 1
    Edit the Boot.ini file to restore or correct the Default entry and to ensure that the other entries in the [Operating Systems] section of the Boot.ini file point to the appropriate directories.
    For additional information about how to edit the Boot.ini file, click the article number below to view the article in the Microsoft Knowledge Base:
    [link=http://support.microsoft.com/kb/289022/EN-US/]289022[/link] HOW TO: Edit the Boot.ini File in Windows XP
    Method 2
    Use the Bootcfg utility in the Recovery Console to correct the Boot.ini file: 1. Use the Windows XP CD-ROM to start your computer.
    2. When you receive the message to press R to repair Windows by using the Recovery Console, press the R key.
    3. Select the Windows installation that you want, and then type the administrator password when prompted.
    4. Type bootcfg /rebuild, and then press ENTER.
    5. When the Windows installation is located, the following instructions are displayed:
    Add installation to boot list? (Yes/No/All)
    [Type Y in response to this message.]
    Enter Load Identifier:
    [This is the name of the operating system. Type Windows XP Professional or Windows XP Home Edition.]
    Enter OS Load options:
    [Leave this field blank, and then press ENTER].
    After you perform the preceding steps, restart the computer, and then select the first item on the boot menu. This should allow Windows XP to start normally.
    After Windows XP has successfully loaded, the Boot.ini can be modified to remove the incorrect entry.
    Method 3
    1. Start the computer by using your Windows XP CD-ROM. Press any key to boot from the CD.
    2. After the setup files are finished loading press R to repair using Recovery Console.
    3. When you are in the recovery console, select the installation to log on to (usually number 1), and then press ENTER.
    4. Login to the Administrator account by typing the password for this account, and then press ENTER.
    5. At the recovery console command prompt, type the following command, and then press ENTER:
    For Uni-Processor systems:
    expand cd-rom:\i386\ntoskrnl.ex_ drive:\Windows\system32
    For Multi-Processor systems:
    expand cd-rom:\i386\ntkrnlmp.ex_ drive:\Windows\system32\ntoskrnl.exe
    Cd-rom is the drive letter of your CD-ROM drive, and drive is the drive letter of the hard disk on which windows is installed.
    6. If you receive a prompt to overwrite the file, press Y.
    7. Type exit, and press ENTER at the command prompt.
    Method 4
    Start the computer by using the Recovery Console, and then run theCHKDSK /rcommand.
    Note You do not have to include the /p switch in the Chkdsk command-line because the /r switch causes the Chkdsk utility to locate bad sectors and recover readable information. This command implies the /p switch..
    Source [link=http://support.microsoft.com/default.aspx?scid=kb;en-us;314477]Microsoft Support[/link]
  3. donkey42
    donkey42 plank
    hi, karan´s way will only work if you are using XP h SP2, if using another version consider slipstreaming your XP CD,
    if all else fails a format & reinstall will sort it, but make sure important stuff are backed up
    EDIT: while in recovery console type
    Code:
    bootcfg /rebuild
    this will rebuild C:\boot.ini, it will prompt you for options and identifier, enter no options, identfier is just what XP bootloader displays
