Technical resource
Discussion in 'General Hardware' started by JimBowen, Dec 5, 2005.
  1. JimBowen
    JimBowen Guest
    hello,
    i really need to find a decent website, that goes into the technical specifications of all computer hardware ie: graphics cards, processors, ram.
    ive been looking for agews but really cannot find anything that helps, i need it for a hardware presentation at college, any help will be greatly appreciated!!
    thanks
  2. Anti-Trend
    As far as I know, there is no such site. The best you can do is hitting www.google.com and searching for the specific hardware in question.
  3. Matt555
    Matt555 iMod
    What is the Hardware presentation on? I'm sure we have enoguh collective people here to over most of what you'll probably need.
  4. Big B
    That really depends on how detailed you want to get too. If you start getting into different interfaces, you have at least 4 types for hard drives (IDE, SATA, SCSI, Fiber), 6 different memory types---not including various flash memories (DDR, DDR2, SDR SDRAM, RDRAM, EDO, Fast Page to start). How detailed do you want to get? How long does this presentation have to be?
    One place that might be of use is http://www.formfactors.org
    but that deals with power supplies and physical dimensions for various motherboard formfactors.
