Temperature Monitoring...
Discussion in 'Video Cards, Displays and TV Tuners' started by pelvis_3, Nov 19, 2005.
  1. pelvis_3
    pelvis_3 HWF Member For Life
    Some may have noticed i recently upgraded my 9250 to a 9600XT.
    Now i've heard that 9600XT and the 9800XT and upwards support temperature monitoring and overdrive.
    Problem is, apparently overdrive and temp monitoring is supposed to be enabled after Catalyst 3.9 and i have 5.8 and there is no overdrive tab in the Control Center or anywhere else i can see. I've also read that for temp monitoring to work, the card needs the LM63 chip onboard and i'm not sure if my card has it!
    Is there just a quick and easy fix available so i can monitor my Vid Card temps or does my card simply not support it?
    Thanks
    pelvis_3
  2. pelvis_3
    Anyone got any ideas?
