http://www.newegg.com/Product/Product.asp?Item=N82E16819103537 http://www.newegg.com/Product/Product.asp?Item=N82E16819103536 what's the difference? I see cores voltages are different.
I'd go for the first one. Its retail so you'll get a warranty and a lower core voltage will probably mean when you oc, you'll be able to put the voltage up ok without killing your CPU.
Well I notcied that the first says 1 GHz FSB and the second says integrated into chip. I didn't look past that.
