Best cooler for pentium 4 3.0ghz prescott
Discussion in 'Overclocking & Cooling' started by Willz, Aug 8, 2005.
  1. Willz
    Willz MiCrO$oFt $uK$ :D
    its called winbond hardware doctor, is there a way to change all settings in pc health status from the desktop?
  2. pelvis_3
    pelvis_3 HWF Member For Life
    i doubt it but you could install it and what it actually does!
  3. Willz
    what?
    winbond hardware doctor does nothing.
  4. pelvis_3
    i meant to say to SEE what it actually does!
    if it does nothing then i dont know whats going on!
    you cant change it in BIOS, you cant change it with winbond hardware doctor, so stuffed if i know.
  5. Willz
    i dont know if i can change or stop computer shutting down in bios, if i know what the setting is that i need to disable then maybe i can.
    is there any modded bioses for my motherboard?
  6. pelvis_3
    well ive got almost identical BIOS to you but i can turn that setting off in mine(under the same category as sated previously).
    the latest BIOS for your mobo is 28/12/2004 but chances are you already have that!
  7. Willz
    yes just updated, there must be some other way to solve this problem other than getting a new motherboard, must be some modder out there that has a modded bios for the dfi inifnity 865pe.
    clearing cmos does not help.
  8. sabashuali
    sabashuali Ani Ma'amin
    Have you tried to Clear CMOS?
  9. pelvis_3
    i couldnt find anything on google but i would just simply not trust modded BIOS as who knows how stable it is! could have a thousand bugs or anything!
  10. Willz
    what is the exact setting in the bios to disable the setting that makes the computer shut down?
  11. pelvis_3
    in my BIOS it is in PC HW monitor and i just vhange the temp shutdown to 100dC
  12. Willz
    is it award bios you use?
    maybe there is some settings hidden from me.
  13. pelvis_3
    phoenix/award (more oc options than just award)
  14. Willz
    oh yea, i have pheonix too.
