Willz
MiCrO$oFt $uK$ :D
HDA normal and sudo.
HDB on sudo
Code:
ubuntu@ubuntu:~$ fdisk /dev/hda
You will not be able to write the partition table.
Note: sector size is 2048 (not 512)
Device contains neither a valid DOS partition table, nor Sun, SGI or OSF disklab el
Building a new DOS disklabel. Changes will remain in memory only,
until you decide to write them. After that, of course, the previous
content won't be recoverable.
Warning: invalid flag 0x0000 of partition table 4 will be corrected by w(rite)
Command (m for help): sudo fdisk /dev/hda
Building a new sun disklabel. Changes will remain in memory only,
Drive type
? auto configure
0 custom (with hardware detected defaults)
a Quantum ProDrive 80S
b Quantum ProDrive 105S
c CDC Wren IV 94171-344
d IBM DPES-31080
e IBM DORS-32160
f IBM DNES-318350
g SEAGATE ST34371
h SUN0104
i SUN0207
j SUN0327
k SUN0340
l SUN0424
m SUN0535
n SUN0669
o SUN1.0G
p SUN1.05
q SUN1.3G
r SUN2.1G
s IOMEGA Jaz
Select type (? for auto, 0 for custom):
Select type (? for auto, 0 for custom): 0
Heads (1-1024):
Code:
ubuntu@ubuntu:~$ sudo fdisk /dev/hda
Device contains neither a valid DOS partition table, nor Sun, SGI or OSF disklabel
