Ne Build need Some help
A fan for what? The motherboard itself uses passive cooling, so you do want to make sure that the case itself has decent airflow. the chipsets must not get warm enough to require active cooling, as Asus and a few other companies have been using passive cooling of some type on the nForce chips. If it was required, you can bet that there'd be a fan on the places that needed it. You probably can add a fan. Again, if you've got decent airflow through your case, you'll be fine.
The CPU's you've looked at are retail version, all of which come with a heatsink for the CPU.
Ok, This should be my last post before purchasing everything
This is what I decided on:
Motherboard
ABIT AN8 32X ATX AMD Motherboard - Retail at Newegg.com
Processor
AMD Athlon 64 3700+ 2000MHz HT Socket 939 Processor - Retail at Newegg.com
RAM
OCZ Performance 2GB (2 x 1GB) 184-Pin DDR SDRAM Dual Channel Kit System Memory - Retail at Newegg.com
Video (2 for SLI)
eVGA Geforce 7900GT KO 256-P2-N564 Video Card - Retail at Newegg.com
Optical
ASUS Black ATAPI DVD-ROM Drive Model DVD-E616AG - OEM at Newegg.com
Hard Drive
Seagate Barracuda 7200.9 SATA NCQ 3Gb/s 160GB 3.5" SATA 3.0Gb/s Hard Drive - OEM at Newegg.com
Case
Lian Li PC-65B Black Computer Case With Side Panel Window - Retail at Newegg.com
Power Supply
OCZ PowerStream OCZ520ADJSLI 520W Power Supply - Retail at Newegg.com
Display
BenQ FP71G+ (Black) Black 17" 8ms LCD Monitor - Retail at Newegg.com
Once again, just looking for someone with a trained eye to look this list over real quick,
Am I going to need any more fan,cables, cords, wires, special tools?
Once Again HWF thanks soo much for the help everyone has given....
-Maniac:dogrun:
(Any suggestion for a cheap but reliable keyboad/mouse :cool:
The setup looks fine, as BIG B said the fans supplied are fine the case comes with a 120mm I believe and your heat sink should be fine. I would suggest you get a good set of small screw drivers and 2 large philip head screw drivers ( anti shock if you feel insecure) and a Anti static wrist band for safety since this is your first build.
Do not work in a carpeted area with just socks try to work in a hard floor area on a table for the build. You definitly dont want one little electric shock to fry all those expensive parts. Last, but not least dont screw the motherboard on too tight.
P.S. All IDE cables and such are supplied with each part as needed.
Keyboards:
Wireless - 39.99
( after rebates)
Logitech Cordless Desktop S 510 2-Tone RF Wireless Desktop - Retail at Newegg.com
Wired- 17.99 ( no rebates)
Logitech Internet Pro Desktop Black Wired Keyboard - OEM at Newegg.com
Your hard drive and optical drive are OEM, so you'll get the drive only. However, you'll have the IDE and SATA cables you need included with your motherboard, so unless you've seen a different cable you really like, everything is included.
If you want to look at a different CPU heatsink, that's fine, but what's included with the CPU will work.
The case includes fans, but if you want to opt for something else (like using some low RPM fans---Vantec Stealth), then you could buy them. Not necessary, however.
Basically, the componets you're listing will provide you with the connections needed...mostly due to the accessory package of the motherboard.
My fellows, a big thanks to each and everyone of you guys/gals who have helped me out on my journey... and I'll be sure to let you all know how everything goes once I get everything in, assembled and started...
-Maniac
Hey Everyone.... I figured I keep this post in this same thread since it just a follow up on everything....
First off everyone who helped thanks a lot, I really appreciate it, All the help made my first PC Build a breeze and joy to do....
And Secondly... All my parts came in yesterday (Thursday) and I finished all assembly and go the rig up and running in just over 2 hours..
Mania Computer - Photobucket - Video and Image Hosting
Above is a link to my photobucket album that has about 9 snapshots...
(I know the date is wrong on some of the picutres {{Camera got reset somehow}}):D
THANKS AGAIN HWF...
-Maniac
